Greetings everyone! I have a few quick questions that hopefully some of you can answer for me. First, how many more rpm's will I be turning at oh, say 60 after changing from 3.08s to 3.73s? Will the difference be consistent at all speeds? And also, how do I go about recalibrating the speedometer? I picked up a complete rear axle from a 94 Formula that's been freshened up and has 3.73s, and I'm thinking about throwing it under my 97 when I redo the suspension in a few weeks... thanks in advance for any help : )
Geads and speedo
Re: Geads and speedo
you will need to reprogram the pcm with a mail order tune or find someone with hptuners to program it for you.
the dealership thing was with a y87 vin as that had 3.42s if you had gone to 3.42s, with the 3.73s you will need the pcm tuned with hptuners or mail order.
Ok, I had read somewhere about the dealer using the VIN from a different car, but I wasn't sure whether or not their programming was limited to just factory ratios. I guess I will have to wait a little while to do the swap. Anyway, what about the rpm difference? I road trip this thing a LOT, so hopefully it won't kill my mileage too bad. I'm guessing about 4 or 500 more, but idk..
Originally posted by 30thAnniversarySixer View PostGreetings everyone! I have a few quick questions that hopefully some of you can answer for me. First, how many more rpm's will I be turning at oh, say 60 after changing from 3.08s to 3.73s? Will the difference be consistent at all speeds? And also, how do I go about recalibrating the speedometer? I picked up a complete rear axle from a 94 Formula that's been freshened up and has 3.73s, and I'm thinking about throwing it under my 97 when I redo the suspension in a few weeks... thanks in advance for any help : )
Your actual speed will be about 20% LOWER than indicated. For example, 70 on the gauge is actually about 56mph, 60 is 48, 50 is 40, 40 is 32, etc.
.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
You'll have some problems since your a auto, I would have your pcm tuned before hand so it doesn't break anything.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
