a guy here in pcola has a rear end up for sale with a posi and 3.42 gears in it. i currently have 3.23 gears in my car with a t5 tranny. how much will my mpg city/highway suffer if i install this rear end and what will my top speed in second gear be? i would really like to know before i go out and get this rear end.
question on gear ratio 3.43
Re: question on gear ratio 3.43
doubt you'll see much of a change in gas mileage at all...you probably won't feel much of a difference at all.
http://www.f-body.org/gears/
I first went from 3.23 open to 3.42 LSD and it was night and day difference, also had a ALM. driveshaft installed as well same time.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
your talking pcola florida?? My hometown is Daphne.
My car came factory with the 3.42s, and I'll be putting a 5spd behind it when I get back to the states.Team NoVa
At sunny south? I have been over there a couple times. I was on southernfbody, didnt seem to active, i still snoop around sometimes over there. The mx6 seems like it would be more nimble on that little course.Team NoVa
Ever tried left foot braking with that MX6? Might help with some of your issues in leaving the corners.
As for the gear change, it shouldn't be a noticeable change in gas mileage from 3.23s. Acceleration should pick up a bit though.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
ok thanks. i never got the hang of left foot braking since i started out in a 4wd audi quattro now the mx6 and the camaro. i may try it to see what it does but i would rather set up the car so i wouldnt have to. im still working on my heal and toe since the mx6 used 2nd and 3rd gear for almost everything and im going to be using 3rd more now since i put the stock turbo back on. im going to try some toe out to see if that will help at all for the turn in.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...23 hours ago
