I recently got a problem with the shifting in my car. Shifts fine when i first start driving it. But once the engine is warmed and after alot of stop and go or awhile of driving the car it starts to shift hard from a stop and only through the first change in gears after that it shifts through the rest of them fine. Its an A4
hard shift
Re: hard shift
I have/had this problem. And it's leaking, but the hardshift just went away. I've just been being nice to the tranny everywhere I go.Wait, Is that a V6 or V8?
Re: hard shift
Theres no leaks i changed the filter in the pan last year, got a new gasket and sealed her up well. It doesnt try to pull from a stop. I was driving on the highway that day also although i didnt keep track to see if it only does it on the highway. My biggest question other than what the problem is, is if not fixing it soon can lead to other problems? ill start troubleshooting with your suggestions. thanks alot guys. I like having a gf that doesnt know anything about cars as she said to me the diagnoses of the problem was "your tires are probably over heated because you havent rotated them"?? lol didnt say anything to be nice.
Re: hard shift
Its the TCC I'm 99.8% sure. There is an GM TCC update. What is going on is there is a valve, the TCC valve which is a piston inside of a bore. The piston inside is what causes the torque converter to "lock up" once you are in the desired gear. If fluid starts seeping past the piston in the bore then the converter doesn't ever reach lock up. At that point the transmission sees that, and increases the line pressure to try to get the converter to lock up. The way to really know if this is your problem is this: when your driving can you hear the engine revs changing up and down while the converter reaches lock up and then unlocks again. If you have the chance, go to a local parts store and have them check for codes, your gonna be looking for p1870, a component slip problem.Team NoVa
Re: hard shift
I know when I first installed my A4 the wire that goes to the TCC lock up wasn't in all the way and when i would come up to a stop the car would want to die unless I put it in Neutral. The Torque convertor was trying to lock up but had no function since the PCM plug was not in all the way, but the TCC will lock up in 1st through 3rd I believe, and forth is just for cruise, I think it is, don't qoute me on it because on the dyno I tried to get it to lock up in 3rd.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: hard shift
Originally posted by Blizzard242 View PostFlaming, how does that affect his first shift from a stop? Doesn't the TCC only try to lock up in 4th gear?Team NoVa
Re: hard shift
Originally posted by flamingchicken View Postyes, but the line pressure still stays raised even after the car slows down, and reaches a stop. So it's kinda like there is a shift kit installed, the line pressure is raised, giving it a hard 1-2 shift.
TEAM C6V6
Re: hard shift
No, It locks up in 3rd and 4th with GM's settings. You can make it lock up in any gear except reverse with HP tuners. A mechanical problem can make it try to lock all the time.sigpic
Re: hard shift
Originally posted by bigbrian442 View PostNo, It locks up in 3rd and 4th with GM's settings. You can make it lock up in any gear except reverse with HP tuners. A mechanical problem can make it try to lock all the time.Team NoVa
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 day ago
