Pitting Chrome Rim Repair - FirebirdV6.com/CamaroV6.com Message Board
  • Pitting Chrome Rim Repair
    So over the last few weeks I have been repairing the pitting and peeling of the inside of my Z06 chrome rims. The first pic is before, then the second is after I used a wire wheel on it for about 45 mins and then the third is after I painted over it with chrome paint. this was done to all 4 wheels.
    Before:
    1) Use a dremel or drill with a wire wheel brush bit.
    2) No wheel prep required before using the wire brush. Use the wire wheel brush to remove the dirt/grime/peeling/pits of the chrome. In terms of movement, I found that going back and forth from the wheel spokes back to the backside of the rim and vise versa worked the best. If you go in a circular motion, you will end up with swirl marks. Dont be a girl with the wire wheel. You really have to put some muscle in it to get all the crap off. It took me a solid 30-45 minutes for each wheel. 1 18v battery per wheel I went through.
    3) Put on the grass face down and hose off the excess residue
    4) Towel dry the inside for a clean shine. You will still see the remains of the pits. I suppose to could use the wheel brush even more to get down to make it flush but After I painted I do not feel this is necessary. (220 grit sand paper should take care of it if you feel the need) The paint covers it up pretty good.
    5) Cut a piece of cardboard to fit the inside circumference of the wheel. It has to be a tight fit or you will get the paint on your actual rim face. This can be tedious but do it right. What I did, was since I couldnt get a perfect fit I took a crescent shaped cardboard and made it fit the curvature of the wheel perfect and then moved it around as I painted.
    6) With the rim face down on the grass, cover the tire that is facing up so you wont get spray paint on the tire.
    7) I used chrome spray from OReilly's with a shaker ball. Shake well
    8) If you do the crescent cardboard piece approach, move it around the inside of the rim while you lightly spray paint it. Use light controlled strokes. I went around the inside of the rim this way twice back to back, no waiting.
    9) Let dry
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    Re: Chrome Rim Repair Pics
    i wish i wasn't lazy this needs to be done to my car =\
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
      What type of chrome paint did you use? Was it from a rattle can?
        i think this would be valuable if scholtzky put this in the how to section
        Robby
        2001 Chevrolet Camaro 3.8 V6
        |JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
        http://speed-bros.com/
          I hear ya. FuryCharger, if you make this a bit more "how to" style, I'll add it to the sticky.
          1996 Chevrolet Camaro
          1995 Buick Park Avenue Ultra
          --Appearance Moderator--
            Re: Pitting Chrome Rim Repair
            Alright, it's up.
              Thanks much. How do you embed the photos like you did?? All I can do is attach them it seems like.
                My old SS 17X9 chrome rims 2 of them the chrome was rusted out since I got them from FL. and the air wouldn't hold any more around the edges, But this is just for th inside the rim. But for the leaking rims I had to either have them re-chromed which was going to be more than the rims themselves or buy new ones or try bead tar but would have to be used everytime I got tires, so I got new ZR1's which won't rust in AZ. Good writeup though on the inner part , they look new again.
                  If you click the attachment it opens a new window with just the picture. If you copy and paste the URL, and stick it between [img] tags, it will embed.
                    I should do this too, I have the stock chrome rims and they look just like this. I thought chrome was supposed to be more immune to corrosion than this. The face of the rims looks great, but that inside part looks awful on mine too. My car has hardly ever even been driven in snow/salt or even wet weather. It spends probably 95% of its life in the garage and is washed regularly. I wonder how well paint will hold up long-term.
                    • Andy H
                      Hello everyone!
                      by Andy H
                    • 3.4 slow to go
                      hey there strangers!
                      by 3.4 slow to go
