So who can give me a good link to a guide to pull the 3.8L engine/a4 tranny out of my 1998 Camaro?? :)
Pulling an Engine
Re: Pulling an Engine
don't have a guide right handy, but thru the bottom is easiest.
MISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
your not gonna take the engine/transmission out through the top unless you want to take your hood off and dissemble the front end
then all you would need to do is unbolt the trans mount, engine mounts, and all of the wiring crap, and the exhaust
why do you have to have it out the top?
It can be done and has been done many times, you have to remove the heads, intakes, and such along with the fans and radiator to do it. Some leave the radiator and carefully do it
speaking of pulling engines, there was a write up i saw somewhere with a white LS1 car that used a lift, anyone have a link to that?Team NoVa
z28 or 3800.. doesnt matter thats what I used to take my trans and motor out.
as far as taking the motor and trans out the top, you have to take the top intake off, headers, heads, damn near everything up front...
trust me when i say its EASIER to take the motor from the bottom... even the GM manual says to do it that way...
you can also use the search feature on the boards.. its a great tool, but you will only find a COUPLE people on here that have taken it from the top... but wtf right? we dont know what we are talking about
ArcherMISC: 01 parts. Some interior, T top kit, seats etc.
Originally posted by Archer View Post... but wtf right? we dont know what we are talking about
ArcherTeam NoVa
Originally posted by flamingchicken View Postthats what i was thinking...i just wanna go ahead and take this time to apologize for being a crappy newb at some point...
Im not one to ***** at someone, but you dont pop in ask for advise and act like the people that are trying to help are full of it.
as far as a guide on taking it from the top, I have yet to find one, and I have had many sites about taking the engine and trans out for appx a year now. If there is one out there, I have yet to find it.
6 bolts, trans mount bracket ( 4 bolts) remove drive shaft, and raise the car.. well disco break lines, sway bar, and anything else attached to the k member.
besides if your car has AC, the compressor is a PITA to take out. with the compressor there, its damn near impossible (possible) to take the pass side motor mount out without (almost) killing yourself. GM says from the bottom for a reason. why make things harder.
and it doesnt matter if its a 3.4, 3.8, LT1, or an LS1... they all use the same method.
someone really needs to sticky an engine removal...maybe someone who is about to do one...me.Team NoVa
Originally posted by flamingchicken View Postsomeone really needs to sticky an engine removal...maybe someone who is about to do one...me.
werd. i just meant one for this site, with a V6 car.Team NoVa
also, i would NOT pull the transmission out through the top while it is still connected to the engine, it is seriously like 21 bolts (counting from my head) to remove the trans from the bottom
the way the fbodies are designed, the engine/trans are so far set back, it makes ot nearly impossible to remove both from the top
