lately ive been thinking about cam compatability with a 4.2L stroker. does a custom grind cam need to be used with a stroked 3800? or would..say a ZZP XPZ cam work well with a stroker
stroker cams
Re: stroker cams
needs to be custom ground as a part of it has to be reduced to work with the COME stroker. A XPZ would not work unless you had the extra work done to it
Re: stroker cams
exactly.
by stroking the motor you're decreasing valve clearance by however much you're adding to the stroke, assuming a flat top piston.
two options= custom cam or pistons with valve recessesY87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: stroker cams
Re: stroker cams
i don't know what i was thinking when i said that...lolY87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Re: stroker cams
Swan racing recommends a .030 to .040" smaller base circle. The XPZ cam will have plenty of clearance w/ a .070" smaller base circle (fwiw, even my GT2 was .034" smaller). ZZP doesn't list the specs on the XPZ cam. I'm sure it would work w/ a stroker kit but probably wouldn't be the best. You'd want to run a bigger cam to take advantage of that extra displacement.
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...3 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
Part 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff.
By: Hib Halverson
At the end of Part Three, we changed the valvetrain of the 3.8-liter V6 in the Tom Henry RS. We installed new, Yella Terra "Ultralite" 1.8:1, aluminum roller rocker arms, Katech valve springs and Katech titanium retainers on our 3800 Series II V6.
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
