It Wont Start!!!! - FirebirdV6.com/CamaroV6.com Message Board
It Wont Start!!!!
  • It Wont Start!!!!
    car will not start...vid will be coming shortly....
    it cranks and cranks and cranks....sounds maybe like it wants to start a bit, but all you hear is a **** load of noise from the around the flew plate and yea, i dont know, take a listen, any suggestions would help
    Re: It Wont Start!!!!
    Sounds like you are getting fuel PSI, just not ignition
    I wanna hear that noise you describe as "flexplate"
    I'm sure that braided line is fine... but give me a minute I'll get some pics
      Oh and also the parking break is stuck on, lol
      any help there?
        sounds vats/passkey related.
        any of that wonderful "security" light thing that I read about a lot come on/flash?
        2013 Ram 1500 Big Horn
        94 comero 3.4
          vats/passkey?
          and im not sure about the light, i didnt pay it much attention.
            well go look if you have a security light flashing or on when you crank it
            2000 3.8 A4 Pewter Camaro
              im gonna scan my dtc's with hptuners today before i try anything.....
              if the light is in fact flashing, what is that telling me?
                vats= vehicle anti theift system for those who dont know.
                i thought with that light on it wont even crank, mine wouldnt. but if its flashing maybe its different. kinda does sound like vats sence its cranking, do you know if you have fuel pressure? and i have no idea why the parking brake is stuck on, ive heard of them freezing on outside, but i dont think your garage is THAT cold.
                  it gets that cold (20*)
                    even at 20 i dont think it'd freeze.
                    i dont think its the vats/passkey, normally the car wont crank at all from my experiences with it even if its flashing. i dont see how it would go bad since the car hasnt been started in a while.
                    Follow me!
                    Or this
                      stupid *** car....still waiting for tim to post the video
                      about to head home in a little bit
                        yea, your right, I wouldnt think its the vats/passkey.
                        My Security light comes on alot... but I'm still able to start/drive my car.
                        1 time when I flashed my car it did make the security light come on. In which case the car would do exactly as dan described (it would act like its trying to start) So I just flashed it back and it was fine. Dont think thats the case here though.
                          well im home now, so i will try to get to the bottom of this....just gotta let the garage heat up a little over 25* before i go out
                            Seems like you aren't getting fuel, did you turn the key in the on position for about 5 seconds, then turn it off, then repeat that step 7 times? this primes your fuel pump pushing fuel all the way up to your rails.
                            Also did you prime the engine? "won't have anything to do with the car not starting but still a good way to build up oil pressure, pull the fuel pump fuse and crank it, then put it back in" well, considering you've already been trying to start it forever I guess it wouldn't be a big deal, lol
                            Camaro V6 - 14.3 @ 96mph
                            Camaro SS - cam/boltons/m6/tune
                            http://www.crfhq.com
                              vats kills the injectors. it'll crank till it kills the battery, well, at least it will w/a 95 3800 setup.
                              94 comero 3.4
