Okay, in my quest to solve my surging idle problem I cleaned out my throttle body today, along with the IAC sensor.
I decided to look at the throttle postion sensor and discovered that at WOT, it only reads 4.36 instead of 5volts as the Chilton's book suggests.
I took the bolts out and turned the sensor towards the rear of the car and tried it again, eventually by moving it about 1/2 inch I got a 5volt reading.
I drilled out the bolt holes as much as I could so i could mount it facing towards the rear abit, and when I got it back on, the best reading I could get was 4.46volts.
So, it appears my sensor is on its' way out.
My question is how will this affect performance? And will it affect my idle??
Thanks!@!
Thanks!@!
