open/close @ .050 camlift
int exh
7 4
56 2
lash hot .022int .022exh
grosslift .460int .480exh
help
1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
never mind i have to pass emissions and i can't with this cam [img]graemlins/thumbsdown.gif[/img] [img]graemlins/thumbsdown.gif[/img] [img]graemlins/crybaby.gif[/img]
even though the peak hp will be past my rev limiter wont it still make good hp i was told if i run a msd i could burn up the extra fuel and pass emissions??
any opinions
Just because you make peak power higher in the RPM band doesn't mean your entire RPM band has more power. The lower RPM's will actually lose more power.
You'd be better off with a cam that peaks around 5200-5500 is your rev limiter is 6000.
Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
