ZZP Rockers - FirebirdV6.com/CamaroV6.com Message Board
ZZP Rockers
  • #16
    <blockquote>quote:</font><hr>Originally posted by bluecmaro96:
    magnus why would you go with comp cam and not ssm cam? what are the hrsp differences and lift duration differences?<hr></blockquote>
    Sorry I'm not Magnus but:
    Stock:
    182/190 115 LS 111 IC
    Camshaft Intake Lift: 0.250 in
    Camshaft Exhaust Lift: 0.255 in
    Intake Lift: 0.413 in
    Exhaust Lift: 0.408 in
    SuperSix:
    210/214 112 LS 108 IC
    Camshaft Intake Lift: 0.281 in
    Camshaft Exhaust Lift: 0.281 in
    Intake Lift: 0.450 in
    Exhaust Lift: 0.450 in
    Compcams
    L67 Lobe Specs
    200°/212° at .050"
    115° Lobe Separation
    L36 Lobe Specs
    206°/212° at .050"
    <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
