Ok well at idle my car has a slight knock. I'm sure someone else has had a similar noise. But my guess is fuel filter, air filter, or A/C. Anyone ever had this or can give me more than semi-educated guess is appreciated, thanks.
Knock at idle?
yeah i had the same problem and it was a loose rocker arm hope this helps. later justin1997 firebird 3.8 y87<br />no maf screen<br />k&n filter charger<br />3.42`s<br />b&m shift kit<br />160 thermostat<br />special grind cam<br />flowmaster cat back<br />rk sport headers<br />bosch platinum plugs<br />bosch platinum plug wires<br />new 02 sensors<p>to come soon<br />slp cai<br />3000 stall converter
<blockquote>quote:</font><hr>Originally posted by onebadsix:
yeah i had the same problem and it was a loose rocker arm hope this helps. later justin<hr></blockquote>
How much did it cost ya to get it fixed?97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
it did not cost me anything to fix it i did it my self all you do is loosen your rocker arm then torque it down to 132 inch pounds then turn the torque wrench an additional 90 degrees. later justin1997 firebird 3.8 y87<br />no maf screen<br />k&n filter charger<br />3.42`s<br />b&m shift kit<br />160 thermostat<br />special grind cam<br />flowmaster cat back<br />rk sport headers<br />bosch platinum plugs<br />bosch platinum plug wires<br />new 02 sensors<p>to come soon<br />slp cai<br />3000 stall converter
By the looks of it the valve covers will be pretty hard to get off? Should I tourque them all down or try to pin point the loose rocker arm?
Also, the motor has to be at top dead center before tightening right?
[ December 12, 2001: Message edited by: RedbirdV6 ]
[ December 12, 2001: Message edited by: RedbirdV6 ]</p>97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
TTT :D97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
since your are going to pull the valve covers i would do all of the rocker arms just to be on the safe side and yes you do need to be at top dead center before tightining them. later justin1997 firebird 3.8 y87<br />no maf screen<br />k&n filter charger<br />3.42`s<br />b&m shift kit<br />160 thermostat<br />special grind cam<br />flowmaster cat back<br />rk sport headers<br />bosch platinum plugs<br />bosch platinum plug wires<br />new 02 sensors<p>to come soon<br />slp cai<br />3000 stall converter
i have a slight hesitation at idle also, but i think i found the source of my problem. the other day at the track i noticed one of my plugs wasn't "snug" on the coil. since it just slides off...that could be a problem. also just check your wires... i had one resting on a manifold, so my miss firing was obivously due to my wires. im replacing them today, so if it isn't then i'll come back to this post.
as far as the fuel filter.. how many miles has it been since you're last change?
good luck.Justin<br />1998 Camaro Z28 M6<br />1985 Pontiac Fiero M5<br />1999 Pontiac Firebird A4<br />AIM: FTBvideo<br />\"Music\'s what I need to keep my sanity!\" --S.A Martinez, 311
I replaced all plugs, wires, and fuel filters -- makes my car run like brand new. Now most of the knock is gone but there is still a slight knocking from around the airbox area? Any ideas about that?1996 Y87 A4 Firebird<br />Black, T-tops, Halogen Headlights<br />Infinity Speakers<br />3\" Flowmaster Cat-Back<br />SLP CAI<br />Rebuilt 3.8 with 18k<br />(Stupid Headgasket)
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...7 hours ago
