I have a stock 1996 Camaro RS 3800 engine. I have stamped rocker arms. I have no idea what fits or what I can replace them with, do you have ideas? suggestions? All I know is I would like to have rollers in, probably have to replace the push rods as well.
What roller rocker arms should I buy?
Re: What roller rocker arms should I buy?
Thanks for the link. I didn't know if I could just replace the arms and rods without any other modifications (regarding ratios, bigger covers to support them, etc) and if they'll mount to the current studs. I took my Valve Covers off to inspect what was underneath and figured I'd replace those stock stamped ones.
Not considering a cam upgrade and I have no idea what ratios I can/should go with. Looks like the default is 1.6.
So why exactly are you trying to replace them?
You know it's never a good idea to just mindlessly voluntarily start swapping parts without cause/reason/ or a goal in mind...
You can do 1.9 with the stock cam.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
They do look pretty cool Mike :) I'm actually considering a set of rollers with a VS cam. My thoughts are that they will take up the slack in the higher RPMs where the VS stops making power. After the troubles you've been having passing emissions, I thought this solution would give me the power I want while passing the idle and 2500 RPM test. I haven't researched it much yet though. Might be a bad combination.
I have the VS cam with 1.7 promag rockers , works pretty well.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Rhunadan View PostThey do look pretty cool Mike :) I'm actually considering a set of rollers with a VS cam. My thoughts are that they will take up the slack in the higher RPMs where the VS stops making power. After the troubles you've been having passing emissions, I thought this solution would give me the power I want while passing the idle and 2500 RPM test. I haven't researched it much yet though. Might be a bad combination.
Rockers are nice if you use them with a cam, by themselves I don't know they'll give you too much...
Originally posted by ssms5411 View PostI have the VS cam with 1.7 promag rockers , works pretty well.aka FreedStyle
Chaddrich Freed
(1 of 443) 2002 SLP Firebird GT #107 (244rwhp/254rwtq naturally aspirated)
2008 Silverado Crew Cab 5.3L 4x4
Originally posted by CFreed11 View PostDo you happen to know the part number for those?
They stopped making them , so no I don't , just need to watch for sale threads.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I had the valve guides milled down some so I had extra clearance.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
