Going to Atco on April 20th !!! - FirebirdV6.com/CamaroV6.com Message Board
  • Going to Atco on April 20th !!!
    yay...going to track on next thursday...first time since i bought it ....i have a few questions about what should i do...here's what i have done or what came installed ...
    *y87 from factory lsd +3:42s (atleast that's what previous owner told me !)
    *slp manual fan switch
    * Austin SS ram air intake.
    *Front tire pressure 36, rears 28
    *2-3 gallons of gasoline atleast 93 ( or should i put 94? i can but then i think that it might not be as fresh)
    *Ok now what else? i am mechanically inclined so, belt mod or open header no good for me....tell me some more tips and tricks....
    very IMPORTANT....on a automatic, how can i launch d or d4 or 1-d4 (manually)? what are the lauching technique??i think my lauching sucks? thanks
    09 Nissan 370Z MB M6 Sports Package
    www.the370z.com
    Re: Going to Atco on April 20th !!!
    How about read up in this section?
      ok i found a bit of info ..
      Originally posted by camaro_speedemon
      But seriously, DO NOT DROP YOUR TRANNY IN GEAR!! leave your car in drive (Don't shift it manually, you'll hurt your time), put your foot on the brake, and rev up to about 2-3k RPMs. When the last yellow lights up go (to get a good reaction time, by the time you go the light will be green)
      but if i put my car on drive and brake at the same, then rev it up to 2-3k , my rear wheels gonna be spinning like a crazy...it's like burnout....???? ..did i missed something??
      www.the370z.com
        no not really. theoretically it could but not at that low of an RPM. if you rev it up higher than yes it will be like doing a burnout but at that low of an RPM your tires will not break loose. your car will be trying to move forward and your brakes are holding it in place. so when the light turns and you let off the brake its like launching in a manual car
        '99 Camaro Y87 M5 T-tops
        Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
        Car Domain
          Well, I would guess you have an auto.... so you can probably bring the rpm's to about 2,000 before the tires spin.
          If you had a manual you could go higher.
          By raising the rpm at the starting line you bring the vehicle a little bit closer to its power band.
          Does that explain it?
          BTW, come to e town this saturday.... f body vs stangs!
            yes thats explains . thanks.....
            So, basically all i have do is press the brake , put it in drive and then rev the rpm upto 2000. When the lights turn green :burn: .......sweet..i will start practicing...
            oh man, thats awesome......i mean what could be better than beating the mustangs all day long...... lol..........it would be fun to watch too....but i work on saturday.... i am the assistant manager so it might not be easy to get a day off..but if i can i will deff. join ....btw when are you running your bird?
            www.the370z.com
              Yup, practice that!
              As for this saturday, gates open at 12. I would plan on being there 11ish
              Weather looks sucky... I hope it clears up.
              I soooooooooooooooooooo wanna spray!
                Getting better launches from practicing yet? I used the same technique when I was practicing. I didn't slam the gas the same time I let off the brake because my tires would spin.
                -Rick<br /><br />Bright White \'95 Firebird Convertible 3.4L A4 - Flowmaster American Thunder Cat-back, Zexel Torsen Posi-traction, Black Checkered Stripes, Clear Corners, Misc. Appearance Mods.<br /> <a href=\"http://www.cardomain.com/ride/2077741\" target=\"_blank\">http://www.cardomain.com/ride/2077741</a> <br /><br />AIM ID: AxSlane
                  Well.... regarding practice....
                  Learning to read the track
                  Learning how tire psi front and rear affects traction
                  Learning deep vs. shallow staging
                  Learning how different rpm launches work best for your car
                  Learning how to keep a certain rpm at the line and floor it when it goes green and dead hook.
                  Lots to learn there
                    Lots to learn there
                    James pretty much said it. It will take awhile for you to learn your car...
                    Dont get discuraged if your times arent the best first couple times out. Take time.........
                    Eric
                    2005 Mustang 4.0
                    1996 Camaro Conv
                    2000 Ford Excursion
                    "Darkness Falls"
                      Lots to learn there
                      srry but what is deep&shallow staging?? if its what i think then i think i deep... maybe
                      2001 camaro a4 SOM vert <br />3800 series II <br />flowmasters american thunder <br />3.42 gears<br /><br />its not fast but i drive it like a natural beast
                        Deep vs. Shallow staging:
                        Deep stage: to roll a few inches farther into the beams after staging, which causes the pre-stage lights to go out. In that position, a driver is closer to the finish line but dangerously close to a foul start.
                        Shallow stage: just trip the second set of yellow lights.... and give you more roll out distance (aka a little bit of a run to get going) thus can give slightly better ET's
                        • Vladimir Gecko
                          Low Voltage
                          by Vladimir Gecko
                          I recently ran into a problem where when I drove my battery gauge showed low voltage. I compulsively replaced the battery and it was still doing the same...
                          1 day ago
                        • LETZRIDE
                          New Owner!
                          by LETZRIDE
                          Little work today
                        • LETZRIDE
                          by LETZRIDE
                          Building the Tom Henry RS
                          By: Hib Halverson
                          02-07-2020, 10:30 PM
