I went to the dyno last sunday and i put down 170hp and 210tq at the wheels. Its a stock 3.8 97 firebird. ARe these numbers right? or should i be concerned? Thanks
Dyno Numbers?
Dyno Numbers?
1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQTags: None
[img]graemlins/thumbsup.gif[/img] Even a little on the high side for a stock car.Matt
1998 Mystic Teal Camaro M5
Did anyone else dyno there car stock?1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
<blockquote>quote:</font><hr>Originally posted by Gauvin007:
I went to the dyno last sunday and i put down 170hp and 210tq at the wheels. Its a stock 3.8 97 firebird. ARe these numbers right? or should i be concerned? Thanks<hr></blockquote>
Were those numbers actuals or corrected. If actual then your numbers will be 10 to 12 RWHP lower in difference.
EricEric
2005 Mustang 4.0
1996 Camaro Conv
2000 Ford Excursion
"Darkness Falls"
That is at the rear wheels1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
they where actual numbers1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
they where actual numbers<hr></blockquote>
Then that explains the higher than usual numbers you turned. the next time you get a chance to Dyno ask for your numbers to be corrected. Actuals do not compensate for the Barometer, humidity nor the DA Levels.....I turned 178.4 at the RW SAE corrected. My actual was 184.7 at the RW.
EricEric
2005 Mustang 4.0
1996 Camaro Conv
2000 Ford Excursion
"Darkness Falls"
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
