well i've decided what im going to do with my 83 bird i plan to build...im taking my 350 tpi out of my 87 gta and gonna rebuild it and put a 400 crank in it and a good cam and some headers and a good carb... thoughts? ideas? brand of parts i should use??
the final verdict...
Re: the final verdict...
Originally posted by 96greenmachinewell i've decided what im going to do with my 83 bird i plan to build...im taking my 350 tpi out of my 87 gta and gonna rebuild it and put a 400 crank in it and a good cam and some headers and a good carb... thoughts? ideas? brand of parts i should use??
383 FTW!!!! I suggest going here: http://www.thirdgen.org/techboard/engine-swap/
and do a search on 383, and sit back amazed on the threads that will come up.
also, what tranny are you gonna put behind the beast?, as a stock/mild hopped up one will die a gruesome death.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
My dad had a Vega with a 383, auto and a 4.88 posi. I think his best time was 6.44 @ 109 on the 1/8 mile. He raced that engine for a long time with no problems.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
I'm bad. My dad's was a 377, 400 block and a 350 crank and rods. It was a long time ago. But dad broke the #3 rod twice just trying to work the bugs out this was a 400. So he used a 350 crank and rods and had a lot of fun. just before he quit racing he had it on a dyno 610HP not bad for NA. He had heart trouble and could not race so for the last 15 years he has been into airboats.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
Originally posted by auto666is this a street car strip mix auto/stick , planning single plain or dual plain intake gears?Last edited by 96greenmachine; 02-03-2007, 09:19 AM.
there are build ups, but for a 383 I'd go w/a TH400, bullet proof. The single/dual plane referes to teh intake manifold. Usually single planes are for the racing/ street strip cars, and dual for mainly street. The single plane will give you more high end response, the duall will give you more grunt down low. Gears: 2.73's, 3.23? If this is going to be a street driver you don't want to go too big or the rpm's will be out the roof.... however, if you go auto and big gears, get agear vendors unit, that'll let you have the overdrive for highway use.1978 Formula 461 in progress of being built :rock:
94 comero 3.4
yeah i want it to be quick at the track and good for the street too so im open on any combo of setups for both street/track... possible to get 12's and still drive as a street car? but if it came to a choice of setup ide rather it be better for street cuz im probly gonna drive it more on the road then track
Originally posted by 96greenmachineyeah i want it to be quick at the track and good for the street too so im open on any combo of setups for both street/track... possible to get 12's and still drive as a street car? but if it came to a choice of setup ide rather it be better for street cuz im probly gonna drive it more on the road then track
edelbrock rpm intake would be a good choice 2500 rpm stall converter 750cfm carb and around 265/260 @.500 for a cam i cant recommend any heads but make sure that the flow numbers are with a valve in i know its stupid but some companys do it to trick you into buying there heads have fun edit: the corvette also uses alot of technoligy that he isnt like fuel injection and dual breathing systemLast edited by auto666; 02-03-2007, 07:54 PM.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
