My Mom's car has been eating coolant lately. I keep filling up the overflow reservoir to the full line and going for a short drive then going home to check it and it less than half full! I don't see any coolant on the ground, and can't seem to find a leak. Do you think it is a small hole in a hose or something? BTW her car is a 1989 Mercury Grand Marquis w/ 165,000 mile on it. I just replaced the heater hose, and had her cooling fan motor replaced and it has been fine until now. I have to keep filling it with coolant before she goes to work, and when she gets home it is completely empty. She told me to post this topic before we go to a garage to get it checked. Any help would be greatly appreciated! Thanks!
My Mom's car
you should have put this in the "other rides"
but anyways it could have a cracked head. i had a grand am(yes its not the same but sounds like the problem i had.) that ate up coolant do to this. i was putting about 2 gallons of coolant a day in it. check around the heads for any discoloration.
Follow me!
Or this
Originally posted by vanbibber:
you should have put this in the "other rides"2002 Z28 A4
SLP Lid | TSP Rumbler | P&P Throttle Body | No Cats | 3.42s | M/T Drag Radials | No Front Sway Bar
12.76 @ 108.42 w/ 1.90 60’
it should. im just throwing ideas out there for you [img]tongue.gif[/img]
Follow me!
Or this
I filled the reservoir to full and just took it for a 20 min drive, and the coolant level barely went down. Maybe it just needed coolant?2002 Z28 A4
the upper intake, is it plastic or metal. If it's plastic, check behind the alternator for cracks. The 4.6L they had in those have the tendency to crack. If so, the kit for the upper intake has a suggested retail of like $700. It could be a headgasket and it could be burning it, any smoke?1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
Sounds like a blown headgasket. Is there any smoke coming from the tailpipe? Blue smoke means it's oil, white smoke means it's burning coolant.<a href=\"http://pics.projectpredator.com/thumbnails.php?album=16\" target=\"_blank\">2003 Zinc Yellow Mustang GT</a> 1 of 701<br />ET : TBD<br />But our shenanigans are cheeky and fun! Yeah, and his shenanigans are cruel and tragic. Which... makes t
Originally posted by camaro_speedemon:
Sounds like a blown headgasket. Is there any smoke coming from the tailpipe? Blue smoke means it's oil, white smoke means it's burning coolant.Red 1998 Camaro 3.8<br />K&N and Home Depot<br />2 12\" JL W3v2 Subwoofers<br />-more audio stuff to come-
It's not a blown head gasket, because the oil looks fine, and there is no smoke out the back. The car runs great and idles smooth, so I just think it needed coolant because it is burning it in this hot weather. Maybe I'm wrong? I’ll check tomorrow when she gets home from work to see if it went down at all. BTW thanks everyone for posting!2002 Z28 A4
Originally posted by maxcamaro:
</font><blockquote>quote:</font><hr />Originally posted by camaro_speedemon:
Sounds like a blown headgasket. Is there any smoke coming from the tailpipe? Blue smoke means it's oil, white smoke means it's burning coolant.1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
Sounds like a blown headgasket. Is there any smoke coming from the tailpipe? Blue smoke means it's oil, white smoke means it's burning coolant.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 days ago
