Looks good, I got mine on ebay , I think it was. I think I might have a extra in my garage, I'll take a look.
I can't find nothing in my garage, so far its claimed a tial 38mm wastegate and some new bolts and now a SLP grill insert that was chromed.LOL I'll keep looking though. On mine I just glued it in , but mine wasn't cut out for the opening like yours, I just drilled holes to have some air flow to the engine.
That looks good, I don't know who made mine since I got it off craigslist and the seller just found it in a storage closet and I bought it for $200. I just know its fiberglass and it was new still in its primer.
What was that white car next to you and what did it run? Look like it had a good take off.
Just a little update. Sometime in the future I plan on buying a used ARH Cam for only the cost of shipping. Yes.... the cost of shipping. It had the keyway damaged on it and was professionally repaired and been fine for 3+ years. Only thing I'd need to replace are the springs to the 90# LS6 springs, retainers, rocker arm bolts and gaskets of course. This will probably be a winter project. I don't want to tear it down during the summer if I don't have to. One of the previous owners went a 13.7 with just the cam and a 3200 stall. Since I won't be putting a stall in it, I think it would run low 14s. What a big difference from low 15s lol. Here are some specs on the cam
ARH Naturally Aspirated cam
-210/220 @ .050
-.320" lobe lift on the intake, .512 with a 1.6 rocker ratio
-.320 lobe lift on the exhaust, .512 with a 1.6 rocker ratio
-112 lobe separation
If you DA's are similar then that would be a nice upgrade, but I would do 105LB springs since there suppose to wear less than the 90lb springs.
