I was cruisin in my Z06 late one night
When this old Datsun pulled up on my right
He rolled down the window of his dirty old rag
And challenged me then and there to a drag...
Originally posted by RallyRed 98: seems legit to me. there were a couple of locals running 11s (daily driven too) with high psi SRs in 240s; i think the Zs weigh even less.
Yes, it is legit. Those Datsuns are quite the sleeper. Please don't be closeminded.
Originally posted by KBeezy: SR20DET @ 10psi? Thats less boost than stock :\
But when you increase the size of the runners and such (ie more volume) the boost level drops. The only reason that some of those 4 bangers run high boost is because they have runners that are so small. When you increase the volume, you decrease the boost.
Originally posted by Jerriko: </font><blockquote>quote:</font><hr />Originally posted by KBeezy: SR20DET @ 10psi? Thats less boost than stock :\
But when you increase the size of the runners and such (ie more volume) the boost level drops. The only reason that some of those 4 bangers run high boost is because they have runners that are so small. When you increase the volume, you decrease the boost. </font>[/QUOTE]Doesn't matter enough to drop the boost 2PSI. Hell, The least amount of boost an SR20DET ever put out stock was 12-13psi. Hell, an intercooler only drops boost 1-2psi (on most cars, depends on application and which intercooler) and those are restrictive as hell. But the SR20DET already has one stock so don't say its an intercooler..
Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
