Hey guys, we swapped a 96 3.8 Series II into our 94 3.4 and need a few parts to finish it up. It runs good and goes good but need a couple of things.
Intake (from air filter housing to MAF)
PCM from a 96/97 3.8L/manual trans car
MAF from a 96/97 3.8L/manual trans car (correct me if I'm wrong, how are the Auto MAF's different than Manual Trans MAF's??)
I don't know. It might. I think the 98-02 just had the revamped sheet metal on the front end.
I did find that what I'm calling the MAF - I really mean the throttle body. I noticed on eBay that they are specific to the transmission type (AT vs MT). Does anyone know what the difference is? The car is running better with the PCM from a manual car installed in it. No more high idle issues when it's warm. However, it still has a tendency to stall when pushing in the clutch to slow down. I'd be curious to know if that's due to the wrong throttle body as our 3.8L is from an automatic car.
The throttle linkage and bracket are different on the 96-97. This is a change for the late 95 which used the same throttle linkage (auto) on both. The manual operates the throttle differently, so that MAY be your issue.
Just to add the 97 PCM's with auto and manual have different tunes on them. Manaul has lower timing tables compared to auto's so I would make sure that you flashed the PCM with the correct auto or manual PCM tune. Maf's don't make a different mines a 96' what use to be a manual , now a auto with a 97' PCM. For my throttle cable I used the same bracket going from manual to auto just had to cut the bracket up some so it would work with the auto.
FYI - I'm referring to the throttle linkage on the side of the TB - it is different for a manual vs an auto. The cable for the manual is also longer due to the different linkage.
Robert - owner www.FirebirdV6.com"Mid-life crisis? I'm way beyond that!"
This!
The cable was too long and I had to re-crimp it shorter on the pedal side to take up the slack. Anyone have a MT TB for me?
The MT PCM works good. No more high idle issues when in Closed Loop.
Only issue now is the intermittent stalling when changing to a lower gear when slowing down - the idle will drop to zero. Most times it'll stay around 1k or so, but others it'll continue to drop to zero and you have to start the car mid-corner. Not good!
I did put in new plug wires (one was arcing to the intake!), new IAC and programmed it, and new EGR.
Reason: new parts
I saw you post in the wanted section. I am parting out a 96 Camaro 3.8L with a MT. I have the PCM, the entire intake setup from the filter box to MAF and the MAF. The throttle body sold already though. Let me know if you might want anything.
