My suspension is all stock except for ES sway bar end links and Monroe rear shocks. My question is what are the main symptoms of bad rear LCA bushings? My rear end feels so sloppy.
I get sqeaking going over bumps and a clickclickclick sound when taking off. I've eliminated the torque arm bushing since I replaced it with a ES Poly one.
Other than those noises, youll feel the sloppyness you spoke of. get under there and check the bolts for tightness.
5 hours ago
