I have a 94 camaro with disc brakes in the rear and was wondering what are those weights for on the rear discs? And are they needed? On my drivers side the weight is rubbing the lca the passenger side is ok plenty of clearance.
rear wheel disc weights
Re: rear wheel disc weights
Originally posted by TheGr8Schlotzky View PostSomeone apparently swapped your rear end out for discs, because disc brakes weren't an option on the V6s in 94. Do you have pictures of said weights? I don't know what you're talking about.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 hours ago
