the e-brake is all the way down, even when I lift it up and put it back down it still stays on. The e-brake works fine thou.
That is a switch adjustment problem.
To the OP, I do believe the BRAKE light has multiple uses, mainly for the e-brake, but also to alert you that there may be a problem with the braking system.
It is normal for the brake light on the dash to come on when the E-brake is applied and goes off when you release the E-brake,but if it flickers like comes on and go off when driving then depend on the vehicle your brake fluid in the reservoir is low,if it is top up then it will be a faulty switch on the E-brake or the one in the brake fluid reservoir,check them with an ohmmeter for continuity with the switch open and closed for two to three times also if it can be dismantle clean the contacts.
I am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...
Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...
Building the Tom Henry RS Part 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff. By: Hib Halverson
At the end of Part Three, we changed the valvetrain of the 3.8-liter V6 in the Tom Henry RS. We installed new, Yella Terra "Ultralite" 1.8:1, aluminum roller rocker arms, Katech valve springs and Katech titanium retainers on our 3800 Series II V6. Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...
02-07-2020, 10:30 PM
