Where did you get this from? I have GM 1LE LCA and PHR on my bird.
You have to get them from GM (unless GM is no longer selling them). The part numbers are available on my website.
And the MOOG bushings are NOT 1LE bushings.
correct, someone tried a few months ago and they could no longer get 1le LCAs at the handful of dealers they tried. Hence why I said you cannot buy them. Sure you can find them used around places. Also the lca itself is no different that our LCAs, just the bushing. So getting some MOOG bushings will be like getting 1le LCAs as the rubber is harder than the stock rubber style we have in our cars
The 1LE is NOT the same as the stock. It is made of thicker steel plate.
Putting in MOOG bushings is a very good compromise, but again, a stock LCA and MOOG bushings does NOT make it a 1LE.
Robert - owner www.FirebirdV6.com"Mid-life crisis? I'm way beyond that!"
6 days ago
