My tire are wearing on the outer side walls. The tires have proper psi. it shakes a litte around 30-45 mph. can I adjust the front-end alignment by myself? And How?
You cannot do a 4 wheel alignment on an Fbody, or anything with a rear live axle.
You need a front thrust alignment (2 wheel). You can either go with GM or performance specs. Some suggested alignments are found on my website under suspension tech.
