got subframe connectors on, now clunking from rear!?!?!?! - FirebirdV6.com/CamaroV6.com Message Board
  • got subframe connectors on, now clunking from rear!?!?!?!
    Ok, well those Jegster bolt in frame ties went in great, hardest part was getting the bolts in. I may get it welded on at a later date, to just make sure it stay's there.
    Now.....when I drive and hit a bump, I hear a clunk like somethings loose. I have checked to make sure neither control arm is moving and it is not. I have also re-checked and re-loosened, re-tightened the arms and I still have that loose sound. Now if anyone can help me figure out why they are like this I would be greatly interested.
    I tightend them down while the car was jacked up by the frame. I figured that pre-loaded the bushings which was wrong. I then dropped the car down, loosened them back up, re-tried tightening them and no luck. I am very lost.
    Please let me know what to do or try, or better yet, how to put them on correctly? It is only the front bolts on the LCA's that I loosened.
    Thanks,
    Chris
    LCA bolts & nuts improperly torqued. Too loose and they rattle... too tight and they pop (or clunk). ;)
    Retorque them (nuts and bolts) between 60-70 ft/lbs with the car level on the ground (not jacked up).
    [ January 14, 2002: Message edited by: Jason McCallister ]</p>
    Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
      spunger what kind of diff did you notice when you ported the heads and intake? who did it?
      thanks
      1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
