Torque Arm Relocation Bracket - FirebirdV6.com/CamaroV6.com Message Board
  • Torque Arm Relocation Bracket
    Which one would fit the t5 that comes with the manual cars? Preferably from UMI.
    Re: Torque Arm Relocation Bracket
    It depends on what year your car is.
      You can get the UMI one, its what I run it wil fit both M5 or A4. I've used mine on both. You'll need a one piece driveshaft if you don't already have one.
        There's a couple of choices from umi, which one ate you talking about ssms?
        Car is an 01v6m5.
        I emailed umi and they said none is the brackets work for the v6.
          V8 and v6 rearend and tq arm are the same. I'm out of town right now , when I get back ill post the link to the UMI torque arm I have.
            You mean the bracket right? I already have the new arm.
              Oh , I thought you meant the tunnel mounted Tq Arm.
                So nothing then? Haha, it's all good.
                The tunnel mounted setups look pretty cool. Too bad I already have the arm.
                  i got one but i didn't get one that bolted right up it needed a little modification.
                  http://umiperformance.com/catalog/in...roducts_id=202
                  this is the one i bought all i had to do to make it fit perfect was to re drill the tranny mount hole and cut an inch off the end of the tranny mount section of the cross member
                  here are some pics.
