i have a 99 firebird and i need to replace the front hub. 2 of the lug holes are stripped out and will not hold new lugs. i removed the spindle and the hub assembly as one.
i just want to replace it so i can get it back on the ground with a 4 tires. if i was to go the junkyard what years would fit?
thank you.
Remove the hub from the spindle, and any 93-02 hub will work. Spindles are different for the 93-97 cars. 98-02 are the same spindles. Doesn't matter if it is V6 or V8 either.
Robert - owner www.FirebirdV6.com"Mid-life crisis? I'm way beyond that!"
what is the best solution to seperate the hub from the spindle? i have already taken the 4 bolts out. i really am looking to get this car back on all 4 wheels by the weekend
