Theres a sorta round looking sensor located around where the map sensor is it has an electrical connector going in the top and two hoses coming off it one gets attached to some square sensor in front of it witch then goes to the throttle body and the other goes around the back of the intake plenium to i dont know where but there is anothr short hose the doesnt go anywhere, should it? it has vacuum when the car is started.
Should this hose be connected to something?
Re: Should this hose be connected to something?
you talking about your EVAP system? Sounds like it.
Does sound like the EVAP, I disconnected mine , took off the 2 black boxes, and the line that goes around to the fuel lines. Then deleted the codes with HPtuners.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
It should connect to another black box , that is on the rail coming off the ALT. , then from that it goes to the TB.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
