does anyone knows whats the name of the little programer you plug in to your trani to adjust your gear changes????
programing question
Re: programing question
i dont believe there is anything that plugs directly into the trans. HP tuners has all the things you would need to to reprogram your pcm for gear changes. Or maybe a hypertech would work not sure
Originally posted by BAD BIRD View Postdoes anyone knows whats the name of the little programer you plug in to your trani to adjust your gear changes????
Mini-SRC - Speedometer Calibration
http://www.zzperformance.com/grand_p...=174&catid=107
Not sure if it works for the F body. I know others make them for trucks too.sigpic
BTW you don't plug anything into your trans for rear end gear changes
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...4 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
