hey definitly a noob question but i was wondering what the sensor right behind the throtle position sensor is and if it was the MAP cause whatever it is the o ring on it is broke and im not sure where to get a replacement, i put some rtv sealent on the housining of it cause it seemed pressurized and its holding now but im not sure for how long.
What is this sensor with the broken oring?
Re: What is this sensor with the broken oring?
it has a little metel rod with a spring around it about 1/2 inch long,and the end looks like the top of a bullet, do ya think it will be ok with out the o ring on it and just some rtv gasket??
take the o-ring to the auto store and tell them you need a replacement. they should be able to find one the right size and it shouldn't cost alot. worst comes to worst, I think a new IAC is $35 or so.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
