what percentage should i be around with the ignition timing advance with HP tuners?? right now when im WOT im around 32% i believe according to my log. Any help would be appreciated.
ignition timing advance...
Re: ignition timing advance...
i dont know what your talking about...... timing is degrees not % please clairifywww.turbov6camaro.com
1997 3800 Series II Camaro
im sorry your right...anyways i went out and logged on to scan it and this is what i came up with...
idel-19*
2500 RPMS-30*
3200 RPMS-29*
is this too much???Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Originally posted by Kidcamaro98im sorry your right...anyways i went out and logged on to scan it and this is what i came up with...
idel-19*
2500 RPMS-30*
3200 RPMS-29*
is this too much???www.turbov6camaro.com
nope no knock retard came up....i did have some ealier back in the higher RPMS but i went back and changed the cells and i have zero KR across the boardJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Originally posted by Kidcamaro98nope no knock retard came up....i did have some ealier back in the higher RPMS but i went back and changed the cells and i have zero KR across the boardwww.turbov6camaro.com
ok i just wanted to make sure...im kinda new to this tuning yourself thing with HP tuners...your guide helped me alot tho and i thank youJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Originally posted by Kidcamaro98ok i just wanted to make sure...im kinda new to this tuning yourself thing with HP tuners...your guide helped me alot tho and i thank you
try adding timing 1* at a time then if you see KR just take it back out
this will give you the best tune possible, but note hot weather = more prone to KRwww.turbov6camaro.com
