Well, I put in my Compcamps GT2 cam in my 96' 3.8 camaro. Problem is, im throwing a 0300 code (misfire) because it idles so low the computer thinks its misfiring. Where is a good place to get a chip / computer for my car? anyone know one off the top of your head?
Cam problem.
Re: Cam problem.
Originally posted by AZ3.8CamaroI would just buy HPTuners, you can adjust it indefinately that way.1996 Chev Camaro RS 3.8<br /><a href=\"http://www.cardomain.com/ride/2233257/1\" target=\"_blank\">http://www.cardomain.com/ride/2233257/1</a>
Re: Cam problem.
If you read the info about that cam on zzperformance.com, it warns about that code. It also says that it is not effecting performance so its not too big of a deal.
How difficult was it to install that cam?sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: Cam problem.
To be honest, really hard. The most difficult cam install ive ever done. Total of around 13 hours.1996 Chev Camaro RS 3.8<br /><a href=\"http://www.cardomain.com/ride/2233257/1\" target=\"_blank\">http://www.cardomain.com/ride/2233257/1</a>
Re: Cam problem.
You can't tune a '96 PCM. You'll need to find a '97 PCM first, then either send that off to be flashed or buy the HP Tuners software (which also requires a laptop or PC to connect to the car) so that you can tune it yourself.
I would recommend contacting Texas-Speed, Wester's or PCMforLess and ask about a custom tune for your cam.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Re: Cam problem.
I spoke to Texas-Speed on the phone just yesterday, and they said they'd have no problem flashing and programming a '96 camaro PCM. Which is probally what I intend to do.1996 Chev Camaro RS 3.8<br /><a href=\"http://www.cardomain.com/ride/2233257/1\" target=\"_blank\">http://www.cardomain.com/ride/2233257/1</a>
Re: Cam problem.
you can buy a programer for a 96 from DHP, i did once i cammed the motor and got the p0300 code works purfectly fine and now i can use it to tune for my sc
the thing with 95-96pcms is that they do not have as much memory so they cannot have as many settings for transmission and cannot store mutiple files to switch between
you can get a 97pcm and swap it in and program it alsoLast edited by 96firebirdgt; 04-08-2006, 12:55 PM.3\" Eldebrock catback exhaust<br />rksport powerdyne<br />pacesetter headers<br />VS cam,compcams pushrods,ls1 valves,5 angle valve job,p&p,<br />and total seal piston rings<br /> <a href=\"http://www.cardomain.com/ride/804031\" target=\"_blank\">http://www.cardomain.com/ride/804031</a>
