Yeh so i installed my jet performance chip the first time but when it got done being installed and i fired up my car my gas gauge wasnt working it was either empty or all the way full. So i took it back off and then reinstalled it . same thing ... finally the third time i did it no gas gauge malfuncion.. but the only problem is i noticed that my fans were running when i had it in the first two times and it was an improvment over stock .. the thrid time.. cant really notice a diffrence.. do these chips really work??
Jet Performance Chips??
I had one for a long time until I got HP Tuners. I never had those problems that you did. I noticed an increase in low end torque. Did you make sure you unplugged the battery before you installed it? I think th e instructions said to do that but I am not completly sure.Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...4 days ago
