what exactly should i be seeing for the stock timing at idle. im running platinum spark plugs, and a maft that as far as i know is set at the stock settigs. i ran an autotap scan at idle i was seeing a max of 33* at idle and a low of about 27*. how far off is this? i dont have the enhanced parameters, but im looking into buying them to see if im getting any knock.
25* - 27* would be about right for idle..33* seems a few too high..but it depends exactly at what rpm your car is idling if it goes up and down at all..i wouldnt imagine you'd be getting any knock at idle
Mine sits somewhere around 5°, but it's all over the place....as high as 13° and as low as -2°. Having a hard time with the lope from the cam, I guess.
i played with some stuff, now it's idling right around 25-28. so i guess thats about right based on what dangerous said.
i noticed that on autotap it always reads out as "-25" instead of "25"
why is this.
i also noticed that as i give it more gas (i did a scan driving around tonight) the timing will go down... it would get as low as "-22" or "-18" when i put it into the throttle, but then when i let up it would shoot to around "-40" and then settle around "-28" ish while i coasted. This seems counter intuitive to me. Shouldnt there be more advance when the engine is running faster, or am i missing something.
When you let off the gas, you'll get tons of advance for a short period of time, then it'll settle back to normal. You have to consider the amount of airflow in addition to RPM.
Building the Tom Henry RS Part 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff. By: Hib Halverson
At the end of Part Three, we changed the valvetrain of the 3.8-liter V6 in the Tom Henry RS. We installed new, Yella Terra "Ultralite" 1.8:1, aluminum roller rocker arms, Katech valve springs and Katech titanium retainers on our 3800 Series II V6. Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...
02-07-2020, 10:30 PM
