Can someone help me out calculating for the 36lb GTP injectors. My stock IFR is 22.27 across the board. My fuel pressure is 48-50 psi at idle. I think the GTP injectors are rated at 48-50 psi at idle , so do I just divide 36 by 22 and then mutiply that by 22.27. I got 36.44. I think it is right. I know I'll have to do some fine tuning. Thanks Steve
Calculating for 36lb injectors
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Do what I did. Go to the bin depository for HP Tuners. Find a GTP bin. Copy and paste the table. Worked great for me.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
The stock 98 GTP flowrate Vs. KPA
from 0-100vac
steadily increases from 36.1 to 38.4 across the band.
If you were N/A you would want a steady across the board fuel maybe, like out stock file, but with the charger you'll want to do the same thing GTPs do and steaily increase if from 0-100 vac.
I would copy the stock GTP one and log runs, then edit from there.
36.1 36.51 37.03 37.76 37.91 37.99 38.04 38.1 38.14 38.28 38.4
That is the stock values from 0-100vac for a 98 GTP.
Damm, your maxing the 36lbers. What is the max hp of the GTP injectors? How much hp and tq are you putting out?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...4 weeks ago
