Lean O2 Mystery - FirebirdV6.com/CamaroV6.com Message Board
Lean O2 Mystery
  • Lean O2 Mystery
    Ok, I'm running out of options as to what is making the car throw an SES light up. '96 Firebird, 3800 series II, modified, no cat, no EGR, dyno tuned. I have been chasing this rabit for what seems like an eternity this season. Bank 2 Sensor 1 is throwing both a P0151 and P0154 code (Lean and low voltage).
    Anyway, checked the motor for leaks with a hose to isolate any noises better. Found that at Bank 1, the EGR blockoff plate had been leaking, so I welded that closed, thus, no leak there. Headers aren't loose or leaking (at the heads or y-pipe, no vacuum leaks (well, that I could find) and yet the problem is still there. It also has a subtle surge that occurs when I take it out of gear. The only thing I can guess (which I really hate to do at this point) is that the O2 sensor may be bad (not the stock GM unit), judging from the A/F ratio being good, but the PCM sensing a lean condition, making it richen the mix up some to compensate, but only at the lean bank. Is there anything that I may have missed? I'd hate to go through the dealer, put in another sensor and find out that the problem is still there.
    Re: Lean O2 Mystery
    Did you tune out the EGR?
    1995 Pontiac Firebird
      Re: Lean O2 Mystery
      Yes, as well as the post CAT sensor.
        Re: Lean O2 Mystery
        Could be the O2 sensor, but what do you have in place for one if it's not the stock GM unit?
          Re: Lean O2 Mystery
          I believe it's a Standard Products version (supplier is Advance Auto for this particular place). Had some trouble with HO2s a while back and at the time, the place that had a decent scan tool warranteed them. Of course, after changing out roughly 6 of them since, this could be pointing to the problem. :twak: me for going with warranty stuff. Could just be a second rate sensor, and after changing over and over, what good is a warranty anyway? Other than pointing me in all sorts of directions needlessly. Yeah, I'll put stock back in and see what happens with it.
            Re: Lean O2 Mystery
            You said that the AFR was good but the sensor is reading way lean.
            How did you determine the air-fuel on that bank is ok?
              Re: Lean O2 Mystery
              Snap-On diagnostic computer. Showed all other parameters were working fine, but the bank 2 sensor was reading a low reference voltage (almost no movement within the parameters that bank 1 was in, small changes/spikes, compared to the sweeping changes of bank 1). Also went old school and used a hose to listen to various areas of that side of the engine, from the exhaust to injectors and intake and found no vacuum leaks or unusual noises, O-rings weren't leaking at the injectors and the headers are torqued well. Also tight at the Y-pipe connection and all vacuum hoses are connected and solid.
                Re: Lean O2 Mystery
                I'd replace the sensor.
                IMO, the best sensors are made by Denso, next best are OE GM.
