while scanning my Camaro with HP Tuners, I found that "Trans Input Shaft RPM" stays at 0.0 rpm.
Now I try to find out if there's a prblem or if this sensor just isn't there or not wired in our cars.
Could someone with a Scanner please check what values you get?
4 days ago
