Took Raven for a run, back to the office after lunch (I go home for lunch). Before I went home stopped for an errand. After starting the engine to go home, engine felt like it wanted to stall, and under power would surge and die off but not stall. The scanner is always hooked up but showed no codes. WTF? Finally got a p0102. But was able to clear, still ran intermitently poorly but no more codes until I garaged it.
From the shop manual, and a search, looks like the MAF is "dying"? It is 14 years old. LOL
If you think the MAF is on its way out, unplug it and see if it runs any better. When the PCM sees the MAF failure from it being unplugged, it will run off of the VE table instead of trying to use the MAF reading.
Sorry to be off the topic, but your car has its own website?!??!
Wait, Is that a V6 or V8? 1990 Chevrolet C-K 1500 series 4.3L .. 5spd
1994 JDM Euno Roadster 1.8L 5spd Bolt Ons.. etc 2000 Camaro 3.8L Auto Bolt Ons..etc
1 day ago
