I have a 2000 Chevrolet camaro 3.8 with 130k. I just finished installing a new ICM for a previous misfire code. Now two days later, I'm throwing P0420 but nothing is wrong with my car as far as how it drives. But I need to get this code cleared in order to pass smog. Any suggestions of where to start?
P0420 but asymptomatic
Re: P0420 but asymptomatic
Probably the O2 sensor since you had your CAT replaced. but if its there after you replace the O2 then your CAT is bad. might want to tap on the CAT housing to see if you can hear in loose pieces rattling around.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
