i got my new halo headlights today.. the dual halo ones with leds.. and was wondering if somebody could explain to me which wires i have to hook up into the fog/running light circuit to turn on the halos seperate.. i saw blizzard's tutorial thread but am not sure which wires control the leds and halos...i could really use some help to get these installed
wiring up halo headlights
Re: wiring up halo headlights
you can splice the positive wires from the halos into the positive wires of the fog lights, and the halos will turn on/off with your fog lights via the button above your radio. make sure to ground the ground wires of the halos also. thats how mine are set up, never had a problem.1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...4 days ago
