Hey guys, first post. so i did a search but did not find an answer just a very short discussion. when i am driving my doors become infested with demon souls and start unlocking for no reason at very random times. the only thing that fixes it is to hold down the unlock switch for a second or two. does anybody have a clue as to where i should start to get this fixed? the owner before me got an aftermarket alarm installed but i never use it because he said it stopped working and he disconected some of the stuff???? thanks for any help
door locks?
Re: door locks?
A poor shop will just twist wires together and put tape over the joint when they install alarm systems. Eventually these splices come undone and cause problems later. If you are adventurous enough: open up the dash below the steering wheel and examine all the splices by unwrapping the tape around the splice, examine for good solder or crimp joint then re-wrap with good electrical tape.
Re: door locks?
check the switch for wear also, my fathers car had a bad window switch and would do similar things until one morning it just decided to short out and burn the whole panel up (we are lucky the whole car didnt burn down)
