LED dash lights - FirebirdV6.com/CamaroV6.com Message Board
LED dash lights
  • LED dash lights
    I just swapped my dash lights for blue leds, but now my turn signal indicators dont light up. The blinkers themselves work fine though. If anyone has had this happen to them? any help would be appreciated.
    Re: LED dash lights
    did you forget to put bulbs in the turn signals? or maybe there the wrong kind of bulbs and burned out or shorted
      Re: LED dash lights
      Did you put the bulbs in backwards? LED's are polarized.
        Re: LED dash lights
        If i put mine in backwards they either didnt work or they burned up. I did my truck. I did it from scratch tho I didnt buy a kit or anything.
          Re: LED dash lights
          i changed all the lights, and rotated them to make sure they all light up, witch they did, but im stumped as to why the indicators dont work.
            Re: LED dash lights
            he means + and -
            Leonard
            www.fquick.com/96V6Junkie
              Re: LED dash lights
              you said you tested all bulbs each way and they all lit up and now the turn signals don't work, or you can't get them to work either direction? There is a 50% chance you will put them in the right way each time, but in my experience, it's more like a 90% chance you will be wrong the first time. Start by flipping them around. If they still don't work, the LEDs themselves need to be tested elsewhere. If they are good, there is a bad connection in the sockets, so long as the sockets are getting power, so check that too.
              1996 Chevrolet Camaro
              1995 Buick Park Avenue Ultra
              --Appearance Moderator--
