the left front fog/parking light on my 96 camaro is out and i bought a bulb for it but i have no idea how to go about changing it, i was told to go in from underneath and when i tried it seemed nearly impossible, any ideas what i should do?
Changing a parking light
Re: Changing a parking light
There are 6 (i think) 10mm bolts on the splash guard underneath. Take those off, and put your arm up in there. The bulb is in from the top, rotate the bulb connector counterclockwise and it should pull right up.
In my personal experience, it can be quite a pain to turn it as they can be very tight.
96firebird311, i think you're getting mixed up with the rear side markers, the front corners only come out from inside, and it's with 7mm bolts. the side markers have torx screws tho.
Originally posted by TheGr8Schlotzky96firebird311, i think you're getting mixed up with the rear side markers, the front corners only come out from inside, and it's with 7mm bolts. the side markers have torx screws tho.
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...5 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...3 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
