Dear G*D, what have I gotten myself into? Need Help! - FirebirdV6.com/CamaroV6.com Message Board
  • Dear G*D, what have I gotten myself into? Need Help!
    OK, so my male ego is definitely getting the better of me.
    I have been following this site for about 2 months now trying to convince myself that I can perform mods /work on my own.
    Here is where I am caught up.
    I have recently acquired an Infinity Reference 57611a 6-Channel Amplifier and an Alpine SWR-1042D 10" sub. With both of these items I also picked up the sub enclosure and amp rack from SubThump.
    My ultimate goal was / is to use the amp to power the sub and all four speakers in the car.
    From all the information out here, I have a pretty clear idea of how to wire the sub, i.e. power through the grommet in the firewall, ground, etc. But, just how exactly should I wire the speakers?
    The set of speakers near the rear seats should pose no problem (I think), but how in hell should I run wire from the speakers in the doors to the amp in the rear?
    I will run the power down the passenger side of the car and the RCA cables down the driver’s side to the rear.
    My camaro had the 6 disc changer installed in the rear. So, I yanked that thing to do a initial test on the fit of the Sub enclosure, and sure enough, it doesn't fit. I think the culprit is the bolt protruding up that secured the changer. Any ideas on how I should work around this problem? If you are going to tell me to cut the bolt, please tell me how? You gotta realize, my IQ level is a bit on the southern side (if you know what I mean).
    That should do it for now,
    I thank each and every one of you in advance for any and all information that you can provide.
    Re: Dear G*D, what have I gotten myself into? Need Help!
    Take it easy. Looks like you made some fine choices and are not really having any major problems. Don't get all worked up and frustrated.:)
    Run the speaker wire to the doors through the rubber boot in between the door and the body of the rest of the car. Its not real easy. I used a coat hanger to help me along.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      I hope the 6 channel amp is a temp to pushing the Sub, {Usually} subs should only be powered by mono amps or 2 channel's, but for your mid range the 6 channel will work great. use a fishing line, to get your wires through they sell them for electircians to run wires accross rooms n such. can pick one up at home depot etc..., In our Any car if there is not a screw to take out then it either snaps out or pops' out. be specific and i can answer more detailed. i have a 4 chaneel to and 2 channel amp, I had to run my own wire since the mansoon system wasn't worth a damn but the placement.
      \"its been long over due\"
        Channels 5&6 will be bridged to the subwoofer which is wired in series...... am I correct?
        Red 96' A4 Firebird
        Check it out here!
          then if that is the case it should have it's own crossover to put it on low's like 1&2 channel should be put on full range 3&4 same and 5&6 on low, you can't put sub's on fullrange well you CAN but DONT. And you can't put reg speakers on low range so i hope it has 3 built in cross overs to devide the channels.
          • Andy H
            Hello everyone!
            by Andy H
          • 3.4 slow to go
            hey there strangers!
            by 3.4 slow to go
