8" subs - FirebirdV6.com/CamaroV6.com Message Board
8" subs
  • 8" subs
    has anyone ever tried hooking up dual voice coil 8s to see if the monson whould plus them? how deep is the 6.5 in the sail?
    Re: 8" subs
    theres a write up somewhere in here that shows you how to cut the speaker holes in your C-pillar to fit 8" subs... i dont know about the monsoon part though
    2000 Camaro 3800 A4
      Re: 8" subs
      My buddy has Kicker 6.5inch mini drivers in his rear speaker location and loves them. They sound REALLY clean and sound great back there.
      i would imagine 8inch subs would hit hard back there. I wouldent count on your monsoon system powering them very well. it can only really power the stock speakers at best.
      MSN: inynn666@hotmail.com<br />1996 Arctic white -3800-<br />Pacesetter Headers & Y-Pipe, CAI, LS1 Dual Exhaust, LS1 Driveshaft<br />*15.17 @ 95MPH*
        Re: 8&quot; subs
        Yes, the Monsoon Amp will push a dual voice coil 8" sub (a low wattage one that is). I used a dual voice-coil 8" sub in a drivers-side stealth box...and powered it off the Monsoon Amp, it sounded pretty good. If you are going to try and stick them in where the 6-3/4" subs were, I'd get something with small magnets or as shallow as possible. Also, make sure the 8's you use have dual "4-ohm" voice coils.
        2006 Tiburon
          Re: 8&quot; subs
          Where is the c-pillar?
            Re: 8&quot; subs
            i saw the steps to put 8s in somewhere, i was hoping not to cut the c-pillar. i found an 8 about 3.5" deep, i'm hoping someone knows if these will fit. i think there about 3/4" in front of the the factory 6.5, and i can make a spacer so the speaker wont set as deep in. but i don't want to start this and the amp not push them.
              Re: 8&quot; subs
              there is no c pillar on an f-body
              just a and b, you start from the front, go from a-z then i believe you start numbering, but that rarely happens, but there are 2 pillars on f-bods and they are a-b (i am a firefighter i know these things)
                Re: 8&quot; subs
                i drive a convertable so umm. . no d or c-pillar i guess thats why i got confused
                  Re: 8&quot; subs
                  sorry ive been driving 4 door cars my whole life, im used to saying c-pillar... whoops
                  2000 Camaro 3800 A4
