I have a 2000 firebird with T-tops. I have 2 10' subs in the back with a walmart type wooden sub box. it weighs so much its almost not worth having it in so i was wondering is there another type of lighter box i can get for it, like fiberglass.and will a fiberglass sub box make the subs sound different...like worse. If so are there any other sub boxes that are light weight for me to use.
Fiberglass sub box?
Re: Fiberglass sub box?
worse? no, fiberglass is used on most sound competition vehicles. however I do not think anyone makes fiberglass boxes that you can buy. check out this article
http://www.fbodyaudio.com/articlevie...tealthbox.tech
Originally posted by MrCoffeeworse? no, fiberglass is used on most sound competition vehicles. however I do not think anyone makes fiberglass boxes that you can buy. check out this article
most hardcore comp vehicles use fiberglass these days. mdf is what you get at best buy. when you're getting judged on your install and creativeness you go with something else. as far as performance goes, as long as it has the correct air space and holds the sub(s), a box is a box
Originally posted by MrCoffeemost hardcore comp vehicles use fiberglass these days. mdf is what you get at best buy. when you're getting judged on your install and creativeness you go with something else. as far as performance goes, as long as it has the correct air space and holds the sub(s), a box is a box
You guys are talking about two totally different installs with totally different goals. For pure SPL....MDF is easily the most common choice. For a real show car, fiberglass is the way to go.
Superman, nobody sells fiberglass drop-ins for the camaro/firebird. Sorry. But I would really think about taking a crack at it yourself. It's not NEARLY as hard as you may think. Fiberglass is pretty damn forgiving IMO.
here's fbodies...
http://www.fbodyaudio.com/gallery/1badbird no longer competes, system is gone :(
http://www.fbodyaudio.com/gallery/blknite01
http://www.fbodyaudio.com/gallery/djsexay2 he's sponsered by JBL
http://www.fbodyaudio.com/gallery/album01 actually a memeber of this board
http://www.fbodyaudio.com/gallery/firehawk_526
http://www.fbodyaudio.com/gallery/4thgens <-- mixed
http://www.fbodyaudio.com/gallery home dir with brief descriptionsLast edited by MrCoffee; 05-18-2006, 05:00 AM.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
