I got an eclipse CD5442 off of eBay yesterday. I was installing it myself whicch normally wouldn't have been a problem. I've done a HU install a few times. Anyway, I buy a wiring harness for GM vehicles. And while I'm wiring the Gm harness with the one off the back of the eclipse I notice that there is no ground wire coming from the eclipse! So I'm like WTF! :mad: At this point, I already had my stock HU out and all the **** was ready for the eclipse to be put in so I decided I'd try to figure it out (in retrospect, I think I should have just gone to bed). So I hook up the deck to my car and w/o the ground wire connected and, of course, it doesn't work. Next I take the ground wire that's coming from the GM harness and proceed to put it in the empty holes in the back of the wiring harness from the eclipse. You know, the holes where wires could be, but aren't. Cuz I figured that the ground wire just was yanked out or something. Well, I found where it was supposed to go because upon putting it in the second hole I see a couple of sparks. I'm like cool, I found it. :D So, I try to hook it up now by moving the amp/control wire as the ground one. i just moved it on the harness. Anyway, the deck doesn't work at all at this point and I don't know what to do. The fuses in my car are not the problem. I can touch the red and black together and get a spark but the radio won't power up or anything. I'm pissed! :mad:
There wouldn't be a fuse or something in the deck that I can replace? I want to hook this thing up and I can't even get it to work now. I'm so mad. Anyway, does anyone know what I can do at this point?
