4 channel amp to front or rear - FirebirdV6.com/CamaroV6.com Message Board
  • 4 channel amp to front or rear
    i have a 4 channel amp i am hooking up to my front components and my rear coaxials when i install it do i hook up my rca jacks to the front or rear
    If your refering to the front and rear inputs to the amp then u must hook your rca's to both front and rear. Assuming you have only one set of rca's then u need split them. you can get the 1-2 rca splitters almost anywhere.
    99 camaro conv. 18in 100 spoke rims, body kit, ac delco iridiums, taylor 8mm wires, 2 12\' L7 soloberics with 1500 rms. I think im going deaf.<br /><a href=\"http://67.19.33.20:8080/sig/0G%20Car4.jpg\" target=\"_blank\">http://67.19.33.20:8080/sig/0G%20Car4.jpg</a>
      Yep you need to use both.
        i was talking bout to the cd player, if i recall i have sub outputs, rear, and front, whcich ones? so what can i get this 1-2 rca thing at radioshack or something?
          Well.... you're hooking up a pair of front components and rear coaxils..... [img]graemlins/slap.gif[/img]
          Zero was assuming you only have 1 RCA preout on your CD player. You have 3. No need for the Y-splitter.
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
            Your front outputs on your cdplayer go to front input on your amp. then the rear outputs go to the rear inputs on your amp and if you have an amp for subs then use the sub outputs to that amp.
              Same thing I thought, use the front and rear outputs, not the sub output. Normaly if you have a sub out it's just for lower notes.
                Usually the subout is also non-fading.
                Red 96' A4 Firebird
                Check it out here!
                  damn guys i just went and bought the splitter, no big thing i can take it back, so what run to sets of rca's one for the front and one for the rear? you all make things complicated lol
                    YES!
                    Red 96' A4 Firebird
                    Check it out here!
                      thanks 96 firebird u are a great help not only to me but to this whole section great moderator!!!!
