I was using a "bad boy" horn but my lame mechanic disconnected it and I cannot find the wire that comes from the OEM horn...I looked and cannot find it. Can anyone tell me clearly where the hell it is??:poke:
Horn Location?????
Re: Horn Location?????
:twak:Quit the fighting childeren. Mr. Palm guy, do you know where the factory horn is? If not, it's right behind the front fascia under the coolant overflow bottle. Chances are you should be able to find the wire somewhere under there. Your easiest way to get to it is underneath the car. Just undo the panel.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
