what are the best mods to reduce HP drivetrain loss ??
mods needed to reduce drivetrain loss??
Re: mods needed to reduce drivetrain loss??
are you an auto? Stall converter, aluminum driveshaft, lighter tires/rims, poly motor/tq arm/engine mounts...anything you can do to lessen the load on the engine...so deleted A/c is two less pulleys that have drag on the belt....double roller timing chain...
Originally posted by LETZRIDE View Postare you an auto? Stall converter, aluminum driveshaft, lighter tires/rims, poly motor/tq arm/engine mounts...anything you can do to lessen the load on the engine...so deleted A/c is two less pulleys that have drag on the belt....double roller timing chain...headers, high flow cat, slp loudmouth
powerdyne supercharger 6psi
GT2 cam. all done by myself :banana:
Hell yea
stall converter will help you on many levels
Are you wanting to go faster or dyno higher?2000 convertable Camaro White <br />3.42 LSD<br />9.45 1/8<br />8.72 1/8 NOS<br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/Suspension/driveshaft_loop/driveshaft_loop.html\" target=\"_blank\">Driveshaft Safety Loop Guide + prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/braking.html\" target=\"_blank\">Line Lock Guide + Prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/rearend/rearendcoversupport.html\" target=\"_blank\">Rear End support/girdle/cover Guide + Prices</a>
be fast on the track, not just on paper.
if dyno numbers were all that mattered then there wouldn't be a need for racetracks, they'd just have two guys line up at a time with calculators and their slips in hand lol.pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
gone in body, but not in spirit
lol...if all he cares about is dyno numbers and not going fast...should buy a supra...those things are dyno queens...don't get me wrong, they're fast to...but some of the numbers they put down on the dyno, then the times they run at the track...makes you wonder if its still the same car...
Originally posted by firebird19_99 View Postso is there a walkthrough for that ac delete? mine doesnt work anyways so i wouldnt mind just taking it out
there are a couple write ups on it...basically its 5 bolts or so you need to remove...
Originally posted by LETZRIDE View Postwell for starters you need to either get a shorter belt or a a.c delete pulley...
the compressor is only 5 bolts...I removed the compressor, lines, drier, and condenser...I still got to get behind the dash to remove the evap coil...
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
